rhino
-looks like the wvo was wet,this will end the esterfication process before minimum T is reached! also, the ae process will stop if the temp is not maintained, to restart, reheat. Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
Rhino,
Do the white clumps look like large granular chunks of salt a little smaller than rock salt? If so I would suspect it to be Potassium sulfate or Sodium sulfate that results from the sulfuric neutralizing the caustic that was in the processor from the previous base stage. Water heaters aren't the best at completely draining. If this is the case then adding more sulfuric may be all that is needed. |
so how much acid should i add and how much methanol? thanks for the input
98.5 Dodge 2500 quad cab 4x4 auto laramie.bd twins b100 |
the chunks are not grainular there more like gooey clumps that take a couple mins to settle
Rhino,
If it were me, I would run the pump to thoroughly mix the contents of the processor. Then pull a 1L sample out for a mini batch. To this sample I would add .5ml of sulfuric (erring on the low side not the high), heat to 140F, shake every 15 minutes or so just like any other mini batch. Check the T after about 2 hours (immediately after shaking) and see if there's any change. If there's no drop in titration, then I'd try something else. |
well i reheated the mix to 140 and added 40 ml of acid and 1 gal methanol to try and kick start the process. it has mixed for 2hrs and titration went from 5.5 to 5.8
update T is now 5.1 hopefully it will continue to fall. ? should i keep heat on it the entire time weather the pump is on or off
Well ain't that a SOB.
I thought you said it was a T7 while the white chunkies were stirred up. Did you titrate this last time with the white chunkies stirred up? If you draw a sample out of the processor the same size as the one in the picture and allow it to settle after titrating, is there more white sediment or the same amount? I'm wondering if the T will lower just with more of a run time? |
the chunks do not appear while it is hot so i titrate as soon as i pull a sample but it is getting lower so i am doing something right
Thanks for the update Rhino.
keep us posted on what is titrates tomorrow or later tonight. |
i got it down to 5.0 then added 2.5 gal methanol and 50 something ounces of KOH and processed some good bio thanks for all help i will dry my oil next time
