Sponsors    Home    Forums  Hop To Forum Categories  Acid Esterification    trap grease problems
I have searched the topics about the trap grease. There are still something not very clear.
(1) When the grease trap company clean the traps, they only pump the grease or they need to empty everything in the trap? (The grease is on the top layer while water is in the botom)
(2) What is the average percentage of the oil(grease) in the total liquid pumped from the traps? 30% or less?
(3) After settling the trap grease, can you just get the grease and let the water flow into the sewer? (Since the function of the grease trap is to collect the grease while let the water flow into the sewer, I suppose after the settling, we can also do this. But just not sure.)
(4) I think Acid reaction is what we should start. The problem is how to pretreat the trap grease. There are a lot of contaminations in the grease. How to get rid of them? For example the bad smell?(Sure we can filtered the solids particles etc. But I belive there are also other contaminations that can not be get rid of by filtering) Maybe we can use water washing the trap grease?
I believe convert the FFA to biodiesel is not so complicate, but how to get rid of other contamination(4) is really challenge, any thoughts?
Thanks a lot!
Registered: 17 February 2009Reply With QuoteEdit or Delete MessageReport This Post
As close to everything that's in the trap as possible, not close to everything.
I would think that is close to accurate.
That's what grease trap collectors did in my past experience
Thanks a lot!
Filter and dewater would be my guess.
I have only seen grease traps cleaned one time, this was behind a large restaurant, they had 5 traps. The folks cleaning these out sure had the right equipment, they had a brand new 40 ft stainless steel semi tanker trailer and pulled a vacuum on the entire tank using a big roots-type blower. They used semi-rigid 5 inch diameter hoses that appeared to simply be dropped to the bottom of the traps to suck everything, they did not make any attempt to control the depth of the hoses to only collect the grease floating on the water.
The trap grease that I have seen has been congealed into something like gray pudding, I would think you would have to heat it until it melts before you could do much of anything to clean it.
I have not treated actual trap grease but I have collected some pretty bad dog vomit vegoil, I water wash this with baking soda in the mix, it takes about a week for the bubbling/oil/water/BS/ soap reaction to stop, another week of settling and I have nice pretty clean oil floating above the crud/soap/water, the cleaned oil has only a little smell but the crap on the bottom is REALLY foul smelling.
Doing this type of BS or lye caustic stripping on trap grease will likely convert far too much of the grease into soap so, yes, acid processing to FFA has always been what I have read as the first step to processing trap grease.
Thanks Double D.
30% is maybe a reasonable number as possible biodiesel feedstock. If the grease is too little, for example 10%, I don't think it is worth to do that.
Filter or dewater should be necessary. But this can only get rid of water and solid contaminations. I believe there are other contaimination which can not be get rid of by these two method.
Since the trap is only use to collect the grease and solids, why need to pump everything in the trap? why not just pump the grease while leaving the water in the trap and flow to the sewer? This may increase the grease content and make the pretreatment more easier.
Seems very challenge.
Thanks a lot!
Good information Tim c cook.
what is exactly the baking soda you used? Kind of NaOH solution? Why you use that?
Also, what is the bubbling/oil/water/BS/ soap reaction?
How about only use water wash? Will the dirty things disolve in the water while the clean oil float above the water? (I don't want use NaOH, because it will conver the FFA to soap)
Thanks!
Grease trap waste is very difficult to process, I know, Ive been doing it. Grease content varies wildly from less than 2% all the way to 25% by volume.
The smell is very strong and is difficult to clean out of the oil. Also everything this oil gets in contact with will hold that smell for weeks.
Very few companies will let you collect grease trap oil aka 'brown grease' without proper licensing, bonding, equipment, and at least a $1,000,000 liabilty insurance policy.
Once you pass these fun milestones you have to deal with some of the highest FFA oil you have ever seen. The best I have ever gotten titrated at about 40T with the worst at 94.5T and an average if about 60T (I expect to break the record tomarrow when I visit the town of Buckeye WWTPSmile)
Once you build a reactor to handle a proper acid esterification to deal with such high FFA oil you move onto base transesterification as usual (but with less methonal since you already converted over a large portion of the oil [FFA's] into biodiesel during esterification)
After that there is still one big obstacle, gelling. Grease trap oil is primarily animal fats and will gel at very high temps. This is a problem I am still working on.
It has taken a very large financial investment for me to collect and process brown grease, Im not saying dont try it, because I think its a good step to take, just be prepared to put in a lot of time, energy, and $$$ to making it happen.
Location: Buckeye | Registered: 07 July 2009Reply With QuoteEdit or Delete MessageReport This Post
Very good information!
could you talk about more in details about "and at least a $1,000,000 liabilty insurance policy", How can I get this insurance?
I am not too worry about the FFA, gelling point. The bad smell and contaimination make me feel uncomfortable. The low grease content also is a concern.
Thank you very much!
