Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Acid Esterification    i have problem too
i have problem too
i from sweden and i try to us animal fat and i have problem to get out the biodiesel
i used solid fat that i get from food industry its meet and some chicken fat
it jelly to much and i don't get a way every thing
i try to us acid and it still don't work totally
when i try to titrate (i have problem to do it because its solid fat and need to warm up before i can titrate it an when i put in the solution it get solid again)it show only two and i warm it up more and still shake it and then i can get six but i t not i nuff what i can see do anybody have any idea what i can do
Please help me
sorry for my english Confused
Registered: August 17, 2011Reply With QuoteReport This Post
2014 Sponsor
Has this fat been rendered?
Find out what temperature it turns sold at and keep it 10 to 20 degF hotter.
www.MurphysMachines.Com
Yes it are rendered
and i hold it in 55*c and put in acid and methanol
after i stirring for 1 hour and let it settle for next day and then i heat up to 55 again and put in the koH and methanol stirring for 1 hour and let it settle to next day again but i still have problem with it. i get some solid fat in it
regards
Kim
p.s its 100% animal fat
This message has been edited. Last edited by: kimmens,
Why are you using acid esterification? What is your titration number? Thanks
i have problem with titration but what i get is 4-6
when i put in titration solution it get solid again i try to heat it up but i can get 2-6 in value
but when i shake it for long time i lose the pink colors i see it clumps in the solution
The grease should be without water in it. I do not know what equipment you have. You can try a one stage reaction. If it has very little water in it it should work. Maybe try reacting 500 millilitres of grease with 110 millilitres methanol plus sodium hydroxide or potassium hydroxide at about 55 degrees centigrade for an hour or more with enough mixing during the hour. That might produce a well reacted crude biodiesel for you. Thanks
