quote: the process that uses soybean oil, ethanol and phosphoric acid which makes this an additive to diesel fuel.
Add a catalyst to that list (KOH or NaOH) and it sound like Acid Esterfication followed by Base Transesterfication, which would be the production of Biodiesel...which is pretty much what we are all about 'round here. Start with The Collaborative Biodiesel Tutorial, upper left side, "Getting Started", and read at least those first 6 topics. That covers the Base part, and if you can grasp all that, then you might want to move on to the Acid part, which isn't any more complicated if you understood the Base half, and isn't even necessary for ever batch of soybean (or any biological) oil.
| Location: Southern WI, USA | Registered: 18 May 2006 |    |
First off...thanks you two, for the advice so far...let me see if I can complicate this even farther!!! LOL
In this article, it stated that the phosphoric acid was the catalyst. In this process, there was no soap formation and the glycerin was "absorbed" back into the fuel. The process was, from memory, soybean oil+ethanol+phosphoric acid, then pressurized and heated (heating came from the pressurization) which burned off the water at the same time, and the end product was the finished product, an additive to petro-diesel.
Supposedly, this is a fairly new process and is used a great deal in Finland (I think). This article provided information on the entire process, including the concentration of Phosphoric acid, amount used ratio, etc. I have been researching for this article again for 2 weeks now, and was just hoping on a prayer that someone in here may have heard of this process.
Thanks again folks...and please, keep your comments coming!!!
