1. Yes, correct.
2. FFA is miscible/soluble with the oil. It is most likely dark in colour (as can be witnessed by methanol extraction a la graemethechemist's technique). When esterified with methanol, its molecular weight increases because you are attaching the methyl group to the fatty acid - making a bigger molecule (Fatty Acid Methyl Ester, aka biodiesel). What do you mean by "theoretical yield"? Say you have 100% FFA (free fatty acid) material, if you esterify with methanol then you will have >100% theoretical yield (nearly 110% yield based on FFA amount). If you get my gist. |
