yea to worked..
next time using slightly less acid..say 0.8ml you might find the results are lower. the stuff on top is water/methanol/acid..the acid, of course is why to titrates higher.. if you have some bad oil. say 20KOH do the same test but more acid...20-3*0.2=3.4ml...this time you find the layer on the bottom not the top. being able to drain in large batches is a must. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
HELLO DKENNY,
Oh believe me i have already found your fomula. it's famous. I even read some of your first articles when you were just a pup asking how to do the acid process. I read a lot thanks so much think how far you have come i'm trying to catch up you should be able to hear my diesel approaching soon! sounds like 5 German hammers on a small anvil 300D baby! bye PAO II CELL (501) 230-4784 |
HEY DKENNY,
I forgot to ask. Is the Rooto brand drain cleaner (professional) ok? ie high enough purity (%) i went to their web sight and nothing is posted. nothing on the bottle either PAO II |
should be good enough.
Hey BrianR,
thanks alot man good work thanks for the confirmation dkenny ya'll are really helpful my next batch is going to be a 50 liter acid base/base with a glycerin pre-polish. i'm going to use my main processor. shooting for sunday night late plus monday some and run on tuesday thanks any suggestions other than the fomula that you listed. maybe a little extra acid since the purity is a little low? bye PAO II |
I wouldn't use any extra acid...its better use not enough than too much..
too much will the titration to go up!! and stay up.. not enough will leave the titration above 3. but this also depends what's initial titration.. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
