Biodiesel & SVO Forums Home
Acid Esterification
Can't get titration drop|
Bone dry oil helps but its not required.
water in the acid stage stops the process so the drier the better. if you're getting it to drop from 10 to 5 but that's not low enough for you. Try letting it settle the drain the stuff off the bottom. hopefully it very liquid like water. it should in fact be water, methanol, and H2S04. be sure to wear gloves. I checked the ph of some that I was draining this weekend and it was 2(using a ph test strip, not titration). Then recheck the titration. Ideally it'll drop a couple of points. if you can switch to using KOH its better for processing the higher titrating oils. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
Higher temperature would help speed the esterification. Also constant or frequent agitation.
How often did you shake it, and for how long? |
Any idea how much water it would take to stop the acid stage? I've made passable(don't know if it was high conversion bio) with way more water than this in it. Of course that was with much lower titrating oil.
I don't know for sure I think it around 1%.
Acid Esterification
