Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Acid Esterification    and another thread on the basics...
I'm on a bit of a mission to flesh out this acid esterification section of this forum. Periodically discussion of it comes up (I think in Colin's Continuous Process thread for instance) but if this discussion happens elsewhere in the forum, it eventually gets lost.
Here's a nice explanation of what the exterification reacion is:
http://biodiesel.infopop.net/2/OpenTopic?a=tpc&s=465094322&f=175094322&m=2983035127
dva
Girl Mark,
Eventually I am going to have to turn the 360 litre of chicken fat that I have stored into BD. Looks as if your acid mission may be coming along at about the right time.
regards
dva Big Grin
where the hell did you get 360 liters of chicken fat.. or are you joking?
mark
dva
Girl Mark,
No Joke. I work for a cooked chicken producer. One day we managed to get a contaminated batch of chicked fat (Someone was grinding metal in a cooker and didn't follow the correct protective procedures). So we dumped everything in site just to be safe. I managed to get home all the 16 Kg drums of fat in three trips in my car.
Funny thing is that a few month ago to try and make some space in my shed I tried to give it all away. No one was interested. So I will use it myself.
regards
dva
I too have a source for rendered chicken parts. A friend of mine works in a chicken rendering plant in north Florida (it may even be across the GA border) but he has given me 30 gal's of the oil that comes out of their cooker. He said that he could bring me a barrel every weekend. I have tried to make biodiesel using KOH and NaOH and have not had any luck.
I heat the oil to 150F and add 20% methanol with the correct catalyst (KOH = 9+FFA and NaOH = 3.5+FFA).
When I use the NaOH I get a big mass of yellow rubbish stuff.
When I use the KOH I get a yellow jello substance but there is biodiesel visible on the outside of the mass and up against the glass. I can poke a straw into the mix and get biodiesel to float to the top. I never get any where near the yield I get with veggie oil.
Can anyone give be a starting point to? Confused I have a good supply and wish to make good biodiesel for my truck.
Any help will be greatly appreciated.
Bio-Mike
Registered: 23 June 2003Reply With QuoteEdit or Delete MessageReport This Post
dva
bio-Mike,
Try making up a Dr Pepper (Hail Tilly) test litre using 6 gramm NaOH and 200 Ml methanol. Do the reaction at 55 C and don't forget the very good shaking.
My chixfat produces a very clear bio plus a lot of white stuff. I seem to get about 60% good bio with the above. I notice that the bio stays very thin right down past +2 c when left in the fridge.
I haven't tried any large batches yet using chixfat. Still using up my veggie oil. Big Grin
let me know how you get on.
regards
dva
p.s. Re: I heat the oil to 150F and add 20% methanol with the correct catalyst (KOH = 9+FFA and NaOH = 3.5+FFA).
150 F = 65.5 C which is above the boiling point of Methanol. Come down to 55 c = 131 F
Bio-Mike,
Do you let it cool down some before adding the methoxide?
I believe 150F is hot enough to evaporate the methanol, which might leave you with "soap".
The 55C that is recommended it 131F.
Location: Rochester, NY USA | Registered: 02 August 2002Reply With QuoteEdit or Delete MessageReport This Post
Using KOH in cottonseed but your figure of 9 + FFA has me concerned, sounds a lot like too much catalyst. I use an NaOH equivalent of 4.5grams = 4.5*1.4 = 6.3 Plus FFA titration amount. Works a wonder.
I did try the 9 or 10 plus FFA on an ethanol batch when I was new to all of this and it did exactly as you describe, turned into a yellow solid glop. Melts in the sun, solidifies soon after. Some biodiesel looking liquid but a disaster all the same. Wind back your catalyst, and at worst start very lowwith the catalyst, and you are able to add extra measured amounts with a bit more methanol and do this in controlled measured amounts until you get it to work.
Best of luck, it should work.
Matt
Location: Earth | Registered: 10 May 2002Reply With QuoteEdit or Delete MessageReport This Post
dva
Here you can see the difference between bio from WVO in the left hand jar and bio from 100% chicken fat in the right jar.
DVA,
What is the melting point (or cloud point) of your "kentucky fried biodiesel"?
"Fatmobile 3" '84 MB300D Silver/Grey with dark blue interior. 290kkm My car - 2 tank UCO conversion working well. 22 000 km so far on UCO
"Josephine" '82 MB300D White with Palamino MBtex interior. 385kkm Wife's car. 20 000km on UCO blends.
"Elizabeth" '81 MB 280E Good body now re-engined as a 300D with the engine from the '79 300D.70 litre UCO tank, 2 pollacks switch FP, filters and IP between Start and UCO tanks.
'79 300D poor body (donor & parts)
"Fatmobile 2" '80 MB300D White with dark Blue interior 230kkm (My first MB) - 5000 km on biodiesel / UCO blend - Found new owner (Sold in 2004).
"Fatmobile" a '90 Mazda 2 litre diesel on UCO with biodiesel start/purge. - SOLD in Dec 2003 after 40 000km on UCO.
dva
Tony fWO,
It's a while since I checked it but if I remember correctly it showed no sign of clouding when left in my fridge for a week at +4 C.
which can't be bad. It certainly goes lower than my veg oil bio.
Problem is you, because it is so clear you have to be carefull not to mistake it for water and throw it out.
I have another 360 kilo to proccess when I get around to it. Smile
I have noticed that it doesn't have the 'acrid' smell from the exhaust that I so dislike when burning WVO derived bio.
regards
dva
