Sponsors    Home    Forums  Hop To Forum Categories  Acid Esterification    Sulfuric Acid in Houston, TX
Anyone have a source for SA in Houston? Or nearby? I'd rather buy it by the gallon rather than pay haz-maz shipping charges.
I'd buy 4-5 gallons if necessary.
The more I know about biodiesel, the less I know about biodiesel.
I may come off as sarcastic or funny. That's because I am.
"You have reached Mr Medic, please leave a message after the beep. If you would like to hear this message in another language, move your ass to a country that speaks it."
Life is WAY too short to not laugh anytime you can.
Location: Houston, TX | Registered: 04 December 2007Reply With QuoteEdit or Delete MessageReport This Post
DN
Ace Hardware sells two different brands of sulfuric acid. They are on the drain cleaner isle.
David Norwood
Updated 1/2009 .
Thanks, I'll check tomorrow.
Sulfuric Acid is also for sale at your local auto parts stores...
Usually sold by the pint or so... Battery additives.
I don't know the purity.
DN
I believe the names are Rooto and Liquid fire. A good test for effective acid is to place a table spoon of sugar in a small plastic container.Pour a small amount of acid over it. Within 60 seconds the sugar will react and turn into a larger black blob.
David Norwood
Updated 1/2009 .
Battery acid won't work, only 20% pure or somthing like that.
DN
I ( and others ) have used the Rooto before, it sells for about $16 a gallon .
David Norwood
Updated 1/2009 .
Give me a call at AAA Chemicals; 281-229-3090 is my cell or 281-478-4460 shop. We are in Pasadena.
thanks
Howard
Location: Shoreacres, Republic of Texas | Registered: 27 October 2006Reply With QuoteEdit or Delete MessageReport This Post
