I would think either GC or GC/MS would be a better way to go, use 4 standards for calibration(one each for the mono, bi and tri-glyceride's and the forth an internal standard that is uncommon and comes off the column in between the other standards). Then toss the internal standard into your raw sample for processing.
UV/Vis might also work, probably have some wacked out peak broading that would complicate things. I would think it'd be more effective to merely consider some of the physical properties rather than result to such level of testing (unless your producing this commercially and have the monies for a chemist); consider comparing the viscosities, densities, cloud/gel points, pH, etc. These later are low cost solutions to determining quality. Then there are the bold among us (some times I'm equally brisant) that flirt with disaster running ad-hoc mixtures knowing the weather is relatively the biggest factor once the glycerin is drained off and the BD is in the tank. Not sure if I've helped or hindered. Best of luck, Ralph. |
member 2008 Sponsor |
TB,
No, it produces fatty acid methyl ester, glycerol and soap, in an unavoidable side reaction.
Yes, the reaction can't go to "completion" (if you mean 100% reacted) since each of the three reactions is an equilibrium reaction.
Yes, there are various levels of Tri Glyceride, Di Glyceride and Mono Glyceride. You can see some GC test results here: GC TEST or search for GC. The amount of byproduct is not a perfect indicator of the degree of completion, since it's volume is affected by the soap production, along with the BD the soap traps, and the amount of excess methanol. As a simple test for conversion check out 3/27 test article or the original thread . The test will not tell you much about mono and di glycerides, but it will tell you clearly if you have more than a trace of unreacted tri glyceride. |
