I have just processed a batch with dkenny's simple method of acid esterfication and the Biodiesel seems to be very dark.
When the Acid/Methanol were mixed with the oil... the oil turned very dark (black) like the acid burned it. Everything went quite well. Started off with oil that Titrated @ 16.4 KOH and the acid process seemed to halt at 4.1 KOH which I thought wasn't too bad for such stinky oil with black floaties in it (removed of course). Oh, and I must add when I added the Acid/Methanol it stank 10x worse. Even after 12 hours sitting, there was no real separation except for some methanol floating on top (perhaps?). I did my base process based on the 4.1 KOH end value and it too went well. I did the 5% pre-wash. Drain. At this point my yield was excellent 90%+ and I am happy with that from such oil. I only have a relatively small wash tank 200L (same size as my reactor -- they are 200L HDPE drums decked out like an Appleseed) and I usually get about 150L of Biodiesel per batch. So my washes are only 50L at a time... so I do a few extra. I pump wash!!! So to be kind on the first wash, when there might be quite a bit of gloop producing glycerin and soap. I 1/4 fill the wash tank pass the dirty Biodiesel THROUGH the water and then pump for about 5-10 minutes (Till the water gets murky). Subsequent washes, I hammer the Biodiesel. Fill- pump on - walk away - oops is that still washing (1-2 hours later). And it separates quickly 1-2 hours. As I reach "clean", when it separates, the Biodiesel is visibly "half dry" already. To dry, I remove all the water from the tank and pump for a few hours forcing room temperature air through the top of the wash tank... and it is done. Using the acid/base process everything has still gone like clockwork. Should I be worried about the color of the Biodiesel? I have attached a picture of what it looks like after 2nd wash compared to my usual end result. P1000421.JPG (1,065 KB, 95 downloads) Color |
It looks excellent!
I've seen a lot darker BD that passes 3/27.
When you have different sources you will see a lot of different colors. Sometimes it's even difficult to see the seperation line at the glycerin layer. |
As long as your finished fuel passes 3/27, I say color means nothing. I have noticed too that acid/base processing can make some very dark bio, but it runs fine in my trucks.
'93 Chevy K3500 w/6.5 turbo, 4x4. 11k miles on bio and counting. '02 Ford F350 4 Door Short-Bed w/7.3 Powerstroke. 7k miles on bio. |
That biodiesel is not that dark. I've seen ASTM spec biodiesel that was practically an opaque black, with light honey-colored glycerin sitting beneath it.
Kumar Plocher Yokayo Biofuels Fueled for Thought blog .........../ \.............. fueling / R \ evolution since 2001 '''''''''''''/____\''''''''''''''''''' Sustainable Biodiesel... |
glad to hear it worked..
biodiesel has no normal color if it made from WVO. the color can range from light to very dark..the same as the rest are saying. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
