Sponsors    Biodiesel & SVO Forums Home    Biodiesel & SVO Forums  Hop To Forum Categories  Acid Esterification    Calculating Water Formation during Esterification
Hi-
I'm hoping someone can help me with this calculation. I want to determine the amount of water produced per mole of FFA (let's assume Oleic Acid) during the acid esterification reaction. I will be using conc. Sulfuric Acid as the catalyst.
I am trying to determine how quickly the methanol will be fouled by water formation. And, if there is any opportunity to recycle this stream- and in what concentration with pure methanol.
Nick
Nick Fox
Newport Biodiesel, LLC
nick@newportbiodiesel.com
www.newportbiodiesel.com
Location: Newport, RI | Registered: 20 October 2007Reply With QuoteEdit or Delete MessageReport This Post
Well, I did some investigating and found that 1 mole of FFA, when esterified, produces 1 mole of Water. That would roughly equate to 0.064 grams of Water per gram of FFA (or roughly 1/16 by weight). Or, 0.064 Liters of Water per kilogram of FFA.
For 1,000 Liters of oil with 10% FFA, the esterification reaction would produce 5.78 Liters of Water.
If someone could check those numbers, I would be greatful. I'm not a chemist, I just play one in real life.
-Nick
Nick Fox
Many moons ago neutral posted that the water created was 1/15 of the FFA.
Registered: 01 April 2003Reply With QuoteEdit or Delete MessageReport This Post
