The acid process takes at least twice as long, 4 times would be a better number. You would need at least one settling tank between the acid and base stage. Since a large excess quanity of Methanol is used, a recovery system for the methanol is needed. The sulfuric acid is technically recoverable but requires some expensive equipment do to the high acid level. Depending on the water level in the raw oil you may need to heat it to over 110 C also. Just a few issues that need to be addressed.
