Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Acid Esterification    Acid/Base 3/27 sediment?
Should I see some sediment precipitate out in the 3/27 test after acid/base ?
Salts perhaps ?
Otherwise clears immediately and seems to be a good pass--
Does not look at all like un-reacted oil appears in a base only process test--
Tnx,
ReM
B100--
2004 Motorhome CatC7
Southern Oregon
Am I missing something? I thought the idea of AE was to convert the ffa to ester leaving the oil so you should see a heap of drop out, and i have not heard of performing a conversion test on AE??
Location: south australia | Registered: November 17, 2008Reply With QuoteReport This Post
Test after acid/base. Not after only acid stage..
Tnx, ReM
B100--
Southern Oregon
Sulfuric acid plus sodium or potassium hydroxide makes salt and water. The salt produced is potassium sulfate or sodium sulfate. If I recall correctly the salt precipitated out when I did AE. The salt was a white solid. I was using new corn oil and 85% KOH and 98-99% concentrated sulfuric acid. Sodium sulfate is sometimes used as a slow drying agent, it forms the decahydrate.
yes you cal have salts drop out in the 3/27 test if the sample is taken while the batch is still mixing or shortly after. if you let the biodiesel rest/settle for and hour before 3/27 this salt will fall to the bottom of the processor
Tnx both you and WesleyB... I thought that was probably the case...
B100--
Southern Oregon
