Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Acid Esterification    Problem in bubble washing
I am washing biodiesel in a vertical glass pipe (d=15 cm , h=100 cm) with only aquadest, aquarium air stone and air pump 2 watt. I am adding 1/3 biodiesel into 2/3 water. The problem is that the wash water always became milky althought I have repeated 5 times overnights. What must I do?
I use palm fatty acid distillate, ethanol and sulphuric acid.
Location: Indonesia | Registered: 27 November 2006Reply With QuoteEdit or Delete MessageReport This Post
hi slamet, I'm fauzi from malaysia,
con you provide me some data:
1. Titration value
2. Mixing time
3. Oil - type.
I believe your oil conversion is low.
Registered: 18 June 2006Reply With QuoteEdit or Delete MessageReport This Post
Don't bubble wash!!! Just gently mix the water with the fuel the first or second time. If you VIOLENTLY mix the first wash, you likely will have a tremendous mess to deal with. 10-25% is enough water.
Subsequent washes, mix vigorously, settle & drain.
Then to dry, look up "air drying". Basically you pump fuel to free fall through the air. Much faster and never a problem and no heating required...
<i> "Forget about all the reasons why something may not work. You only need to find one good reason why it will.
Dr. Robert Anthony </I>
2005 F250 6.0 4X4 Crew Cab
Location: Spartanburg County, SC, USA | Registered: 19 June 2004Reply With QuoteEdit or Delete MessageReport This Post
