Sponsors    Home    Forums  Hop To Forum Categories  Acid Esterification    Large scale acid esterificaton
G'day chaps!
I'm looking for a production line that can handle high FFA (45%) oil left after vegetable oil refining. Could you please point me in the right direction? I've got access to quite a large supply but don't know anyone doing this type of biodiesel production. Any imput would be appreciated.
Location: Formerly Brisbane QLD but in Ukraine for the past 15 years | Registered: 15 June 2003Reply With QuoteEdit or Delete MessageReport This Post
I would think that the setup would need 2 or more acid stages. you'll need to settle between the stages.
or ---
since doesn't sound like home brew size setup
something to remove the water during the acid esterification stage, but leave the methanol/acid behind.
sounds like an interesting design/build project to me.
-dkenny
Hi
did anyone find out about this high FFA problem, i have 54% ffa sunflower acid oil and want to know if sulphuric acid will work , and how much to use and what is the % of biofuel after FAME?
Frown
Registered: 24 November 2008Reply With QuoteEdit or Delete MessageReport This Post
try it on a sample.
since 54% FFA is about 95KOH.
I'd suggest 2 stages
95 - 40 * 0.2ml = for acid during the first acid stage. use the same 12% for methanol.
drain after 24 hrs of processing. this will be about 1/2 of the methanol you started with
titrate again - don't assume that it reached 40.
recalculate the acid needed..
titration -3 *0.2. I would suggest using the amount drained.
process again for 24 hrs
settle and drain
mix and recheck the titration.
hopefully its between 3-7 KOH
-dkenny
thanks
i sort of get it, but being a newby could you break it down into baby talk, i would really appreciate it, ive searched the net for days, and your the first person that sounds like they know what they are talking about! I have 60 MT of this stuff(no joke) and i need to know how much sulphuric to order?, or how much acid per MT?
sure
read this
http://biodieselcommunity.org/acidbase/
comment and question here
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/629605551/m/9931007872
-dkenny
