Biodiesel & SVO Home
Biodiesel & SVO Forums
Acid Esterification
KOH test batch making me mad (picture)|
the base for KOH is 8 not 5..5 is for NaOH.
just mix the difference in 1 gallon of methanol and mix in with the rest. you have a major under reacted batch. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
AHA, that would sort of explain it a bit...
So it's 8 g/l of KOH as the base, then add the titration. So, for this batch 120 l oil 4.5 titration x 120 l = 540 g KOH plus 8 g/l x 120 l = 960g = 960 + 540 = 1500 g of KOH to add to the methanol. I'm only 300g off - I put 1200g in. Is the reaction that sensitive? I'm guessing yes. I put that jar of stuff in a water bath at 120F and this morning it has separated to dark brown at the bottom, then that murky milky brown in the picture above, and on the top is a light brown milky stuff. Does that confirm the under reacted diagnosis? I was following the Girl Mark post, maybe I didn't see it was for NaOH Paul 1983 Mercedes 240D Single tank WVO - FPHE, Injector Line heaters, aux fuel pump. Water/Methanol Injection. Frantz bypass oil filter. - North Florida |
300g low is around 20% so if a big difference.
try another sample using correct amount. then you'll be able to see the difference -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
Dkenny,
Where do you get 8g/l of KOH from? Everywhere I've looked it's 5g/l. I titrated the remaining oil, and it is down to 3ml. YAHH! Acid esterfication works! Paul 1983 Mercedes 240D Single tank WVO - FPHE, Injector Line heaters, aux fuel pump. Water/Methanol Injection. Frantz bypass oil filter. - North Florida |
Hello to every body, Im new to all this, and having lots of trouble with it and I see there is doubt about if its 5g/l or 8g/l of KOH, Im using 5g/l and its not going so good.
its been that for a long time.
5g/l NaOH = 7gKOH but adjust for purity 7/0.9 = 7.77 rounded up to 8. sites like JTF still have it wrong with the old values of 3.5g/L NaOH which would 4.9g KOH -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
I did another test batch, now that the acid treated oil has had a chance to sit for a few days.
It titrated at 3ml, so that's great - all the way from 11. It is 120l (30 gal) and I put in total 250ml H2S04. For this test batch I did 50ml KOH at 9g/l (I had already mixed this up so I just used it). 500ml oil. After 30 minutes it has separated well. But the BD is still quite dark. Is that because the acid burnt the oil, or maybe it is not completely converted. How to check? Paul 1983 Mercedes 240D Single tank WVO - FPHE, Injector Line heaters, aux fuel pump. Water/Methanol Injection. Frantz bypass oil filter. - North Florida |
I just did a 24/7 test on the BD - it is under reacted (good call DKenny).
I've put another 10ml of methoxide in it and shook it up and in a water bath at 120F to see how it goes. Paul 1983 Mercedes 240D Single tank WVO - FPHE, Injector Line heaters, aux fuel pump. Water/Methanol Injection. Frantz bypass oil filter. - North Florida |
I always use 7g/L as my base and I use KOH exclusively. I thought you didn't have to adjust for purity if your stock titration solution was made with same KOH that use a catalyst? Or is it just the titrated amount that doesn't need to be adjusted?
its the titrated amount that doesn't need adjusting. the base needs. it also depends on how good is you oil?
Acid Esterification
