Biodiesel & SVO Forums Home
Acid Esterification
acid esterification and 80/20 process|
Generally people have found that doing esterification produces higher conversion quality biodiesel than if you'd not done esterification, so I'd like to know if you actually need to improve conversion or if yours works OK without the extra step.
Doing base-base two-stage may raise the amount of soap you form doing this, so there may be a drawback. ************ Biodiesel Homebrewing and Equipment Classes: www.girlmark.com/tour Biodiesel Homebrew Guide: www.localb100.com/book.html Diary of a Mad Scientist blog http://girlmark.com/blog |
Thanks for the reply.
I do the esterification because the only oil I can get titrates at 9 or higher. |
sometimes my base stage doesn't pass the 27/3 test. So I run a reprocess on the batch after draining out some the glycerin.
I cannot say if more soap is made because I haven't kept the best records on yield and glycerin qty. sorry -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 soon a 99 dodge 2500 5.9l 24v..-mine |
For what it's worth, my oil typically titrates 15 to 20 (KOH). I use acid stage at 13% methanol and base at 7%. Typical soap conent in my raw unwashed, but settled (3 to 7 days) fuel is 1300 to 1400 ppm.
Horn |
Horn,
I am having trouble with my bio diesel making fuel. The glycerine levels are double what they should be and the 3/27 test mostly fail. I am new to this. I use the single step process with too many fails. Would the 2 step be an answer to having less fails with less than perfect oil? thanks, dc |
Acid Esterification
