In theroy your thoughts should work, but let me ask. if you are flash evaporating the excess methanol then why are you concerned about limiting the amount you put into the reaction?
Overdosing the methanol above what is therotecially needed does not speed up the reaction. It allows the reaction to go to completion. Without the excess it will not complete the rection. Logan Vilas |
Hi Rob-
The stoichiometric ratio for the esterification reaction is 1:1 (1 mole Methanol : 1 mole FFA). For oil with a 10% FFA content, this would mean roughly 1.3% Methanol, if I did my math right. Now, this is the 'theoretical minimum' of the reactants. Of course, at this level, the reaction would go no where. Water formation is the main issue to overcome, as it inhibits the reaction (due to hydrolysis re-forming FFA's IIRC?). I hope that helped get an idea. -Nick |
I have seen plants operating that use a 20:1 stoichiometric ratio of methanol so for every mole of FFA 20 moles of Methanol are used.
I qualify this by stating that typically the oil/ester phase is vacuum stripped to remove all methanol and water and the methanol is then dried in a distillation column. |
vegenergy,
i wish I had a good answer for you but I don't use as much methanol as you suggest I only run 12% by oil volume. this is titration upto and including 27KOH(14%FFA). My thinking is restricting the amount of methanol is not with the recovery later but to force the methanol/water,acid layer down. should one desire to drain. this would leave the BD( acid estrification made) and oil on top and left for the transestrification phase. I have been looking over my notes and it seems that for values of titration between 14 and 18 my method works without draining. In a couple of batches ( 25,27 KOH) when I did drain. the titration dropped 4 mls or more. just by draining. just my 2 cents -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
