You can use bead form of Naoh.. Seems as though the most common form of Koh is flake, ask the price difference if there is one.
----------------------------------------------------------------------------- 40 Gallon 2 tank Biodiesel processors, Well built, Easy to use, Quality parts. pm for pictures and details! http://www.revolution-biodiesel.com/ Running B100 in my Ford 2004 and 2005 F-350 Ext Cab |
reason for asking is new supplier said bead was 40% less cost.
03 duramax for now, 10 year TDR member 96 2500,98 3500,2004.5 3500 all Cummins power, bio pro 190 |
I used beads once, they were much more difficult to dissolve than flakes, it took at least five times longer.
Sounds to me like he is confusing KOH and NaOH. KOH is flake and pricier, NaOH is beads and much less expensive. Did he (or you) say lye? Both are often called lye. Make sure you are discussing potassium hydroxide or sodium hydroxide, they are not the same. HTH
Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
An out of the box question... Why use Koh that is pricier than naoh in a biopro?
My guess would be disposal of glycerin? Or a very cold garage. ----------------------------------------------------------------------------- 40 Gallon 2 tank Biodiesel processors, Well built, Easy to use, Quality parts. pm for pictures and details! http://www.revolution-biodiesel.com/ Running B100 in my Ford 2004 and 2005 F-350 Ext Cab |
using KOH you won't turn your processor into a soid mass of glop. I did that once when I first started out. then switched to KOH. I also read somewhere that KOH gives a more comlete conversion ? either way, good luck. Tom
" I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
in cold temps..say less than 40F
think solid vs a gel. even more so if methanol have been recovered. Naoh glycerin will be solid at a higher temp the KOH glycerin other thoughts NaOH -- sodium based.. BAD for composting and water washing with dumping the water KOH -- potassium based.. not so bad for composting and water washing with dumping the water. potassium is a fertilizer sodium is a plant killer. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
