Biodiesel & SVO Forums Home
Acid Esterification
Where to get H2SO4??|
I have found it difficult to get except as battery acid about 30%.
I concentrated the acid from old dud batteries. THIS IS DANGEROUS Charge old dead batteries until the electrolyte density comes up(hydrometer). Tip the whole battery into a plastic tub and empty(Goggles/Gloves). Collect and filter the lead etc out. Settling for a few days gets the finer particles out. If it has a gray tinge it still has lead in it. Heat the acid(outside) at first due to the water content it will boil when the boiling stops it will start to fume that should be about 95% which should do. The fumes are really nasty a mask would be good. Now the bad news the liquid acid can blind and cause nasty burns. The lead in the batteries is toxic. The fumes created when heating are extremely toxic and can kill. The heating must be done outside. A lab with a fume hood would be better. glasses Gloves apron and a bucket of water as a wash. |
Try some cleaning supply stores
Saint Tilly |
Lowe's sells it as a drain cleaner. It's about $9 per quart, and I think it's 95%. It has some black crap in it probably to make it visible.
I use it to acidify my wash water if I get emulsion. colin C |
i get mine from Ace hardware. its in the drain cleaner section
-dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
Hi Ihad a hard time to get also becuase that is a controled chem here in PR but my chem supplier gave me a hint on what to buy ang is turned out to be 99% at my corner store. I'm not sure if I can give you the name in this form but the 1 liter bottle is in a plastic sealed bag.
I have a chemical supply place near me called ChemStation that I can get 1 gal bottles for $10 and it's 93%. I just looked in the phone book for chemical suppliers and manufacturing.
I was looking at Ace Hardware and found the Rooto brand of sulfuric acid. After a bit of digging around for some % of acid I found a MSDS sheet that said it was 93.2%. Is that the same brand you use Dkenny?
no. i use the hot power from Ace, but that should work just fine. you might need slightly more acid than the formula calls for. I'd suggest starting with the formula as is and tweak it after you've made a couple of batches. Its better to use less acid than too much.
Thanks dkenny I'll give it a try.
Wow, guess I got really lucky, last week I had a buisness owner that was moving give me a full untapped 55 gallon drum of 93% sulpuric, this is gonna last me a LONG time, he got it from Brenntag.
fabricator,
MAJOR SCORE!!!! -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
Yeah, and I already have a pair of jeans with holes in em thanks to this stuff, next time it will be full pvc apron and long gloves, this is serious nasty, dangerous stuff.
I get all my stuff from this guy... KOH, Methanol, H2S04,... Fenner Chemical. 989-322-0616 info@fennerchemical.com |
Acid Esterification
