Is the final product cloudy or what? If so you probably dont let it dry long enough take a small sample and microwave it and see if it turns clear. if so then its wet. Also, if washing is giving you difficultes try using less NAOH you may be making too mush soap. I only use 3.5 + tiration 90/10 in two seperate reactions, i never need a third while doing base/base but when useing acid sometimes three bases is nessasary which i think is because of all the water present.
None of this makes amy sense to me.
-bubbling, bioling,brown biodiesel -did this batch pass 3/27 -heating wvo to 140 and allowing it to cool will not remove sufficient water for the ae process -T.4 nooh I don't get it? this seems impossable with the process as detailed Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
Bubbling and boiling meaning when the acid and methanol mix in with the oil there is a funky reaction that looks like a rolling boil.
I bring the WVO to 140 then let cool. The water is left at the bottom witch (halloween and all) is quite a significant amount. I drain that and try a sample test ( heat a cup of WVO or so to see if it spatters) Most of the time it does not. Yes My finished product is cloudy but after awhile ( couple weeks ) it clears up in the barrel. (Titration 4 sorry), from T20 or more after a day or two. Brownish like a golden brown like syrup color but definatly not as thick as syrup nor as dark. lol Bad example I guess. The longer I leave the ae it seems the better but it has to be warm. It seems to not work at all if its cold. I hope this clears some confusion up. I'm not the pro but I am making bio-fuel. Recently I have lost my bio dome location so now I am re - setting up again. Thats another story not for this forum. lol Have a good day Ohhh And I will try less NAOH when Im back up and running. Thanks for the tip. Might save on washing time. And as for washing I do it by hand for a few cycles by a garden sprayer (Pump action) and drain with no agitation THEN do a shakitup test with a litre. If it doesnt glob I add water via house to the barrel(S). Turn ze pump on and mix. Settle. Drain. if water is clear if not add water again. Then dry. Peace out all. Good luck and I hope this helps. You have all helped me a ton. THANKS VERY MUCH And does anyone have a line on inexpensive methanol. Im paying $400 a barrel. TOOOOO much I think. Don't worry about it. Its just a phase! |
You are not getting your oil anywhere near dry enough for a decent acid stage, your results will never be consistant.
