Biodiesel & SVO Home
Biodiesel & SVO Forums
Acid Esterification
Homebrew Acid-Base Biodiesel Recipes|
Tilly,
I will give this a try. Does the methanol play an active part in the acid's reaction with the WVO? I thought it was just something to dilute the acid from burning the oil during initial mixing. Also, given the high temp of the preheated oil, is it of concern that much of the methanol would be evaporated off? Finally, how much time is sufficient for the acid diluted in the methanol to get 6.0 titrated oil down to the 2-3 range? Thanks!
Hello netman352
The Methanol is an active part of the acid reaction that converts the FFA's into methylesters. Evaporation is a concern in the Acid/base procedure. You must have a reactor that the methanol can not evaporate out of. The time for the acid stage will vary. Most people perform a titration every hour and when the titration of the acid stage stops falling they do the Base stage by mixing 5g NaOH+ Titration into the rest of the methanol and perform the base stage. Saint Tilly |
member 2008 Sponsor |
Antifuel1, Sounds like you have a sweet method that works very nice. In an effort to learn more about your method, I do have a few questions. Are you doing this in an appleseed? Have you ever titrated between the acid and base? How did you determine the 6g/liter of base? Do you ever see any dropout on 3/27? Thanks and keep up the good work, DD |
dandy I arrived at approx. 6g/l by expermenting. I did titrate after acid stage last and I was at 1.5-2 It passed 3/27 test 10 times strait so I have not been testing it since. I feel the filtering thru 1mic bag before demething it helps to remove missed glyc and soap before useing an adaption of GL's drying method. This is only my opinion, maybe it works with the mix of oils I use[unknown]. Some of it is only used for a couple of hrs. an some is prety rank. I am expecting better results once I get my cf in operation.I want to try running it thru the cf before during and after the process. I want to see if putting thru the cf before demething it will improve the the percentage of return and also produce a cleaner fuel with less time in the dryer ,also when I build my vac dryer collecting a higer grade methanol because there should not be any water in it. The whole picture gets clearer as all of the good ideas get put in the right spot only problem is it the ideas keep improveingand the picture keeps getting better. Keep up the good work everyone. The only dumb idea is the one that is not checked out and done with safty as the first step.
I have a quick question. When you're titrating, you titrate it mixed up and everything? What would happen if you let it settle and then titrated it again? I'd think this would let the sulfuric acid settle out and lower the titration.
My initial titration values are much higher than most of yours (in the mid-20s) so I expect that I'm going to create too much water to run the reaction to completion. Therefore I'm considering draining and then running the base reaction (with more methanol, of course), maybe even running a second acid reaction. Thoughts? |
Hey RUBI,
My oil usually runs around 22 or 23 KOH. I use the acid/base method routinely. You do make some water that does wind up becoming soap but the additional soap usually isn't enough to justify the additional methanol you would have to use if you dry the wvo before going on to the base stage. If you use KOH it will wash out easily. -mcguyver 2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field. |
Hello rubi
Yes, you titrate everything. The Sulphuric and methanol will be together and you can not remove one without the other. Saint Tilly |
Mcguyver, how long do you usually need to mix your acid stage before the titration stops dropping? I only mixed it for three hours for comparison purposes with another method. Should have been titrating it every hour, but as my last post says I wasn't sure how. So my NaOH titration only dropped from 29.5 to 15 and 16 for the two batches I ran.
Since KOH titrates slightly higher than NaOH, and my titration was a bit more, it won't be a direct comparison, but it should give me an idea. Thanks, RUBI |
Hey RUBI,
I usually run mine for 24 hours before I even start checking the titration. I know that's a long time but that is just what it takes. By the time I get 3 or 4 more hours in the titration has finished dropping. Unfortunately I don't have the time to really "baby-sit" my processor like I should so I use a 12 hour timer and usually check it at the first and second 12 hour interval and then guess the rest of the time needed and set the timer for that. The savings in "production losses" is significant enough to justify the time/money spent running the pump and heating element. I do my processing in an Appleseed so the heat loss is minimal. If I don't do the acid step my glycerin production is almost 50%. Your oil is pretty bad stuff. You will most likely have to do two acid steps to get the titration down were you want it. I have done this before and found it works better if the water is drained between steps. You have to replace the water/methanol you drain with methanol. -mcguyver 2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field. |
What would be the LOWEST titration that it's worth the effort to do the acid stage ?
Yair |
Hi Yair,
It's hard to give it an exact number to say this is the point at which you should do the acid/base process. I've had oil that titrated in the low 7's and still produced why too much glycerin and I benefited in doing the acid/base process. Basically you should do a minibatch on an oil and immediately after you get done agitating the minibatch fill a 100ml graduated cylinder and wait to see the results. If you're getting 35 or 40 ml of glycerin then it is likely that the cost of the acid and the additional electricity out-weighs the cost of the large amounts of catalyst and the lower production yields. -mcguyver 2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field. |
Hi mcguyver
Thanks for your answer. I get about 20% glyc. I titrate the oil at about 1.7 ( a mixture of 2 different sources). The additional electricity is nebligible, so maybe it really may be worth the effort for the additional yeald. Your thoughts? Yair |
Yair, The only way to know for sure would be to do some minibatch test to see if the yield would change however, I would wager against any significant increase in yield. With oil that good I would just process it and enjoy the bd. 20% glycerin isn't out of line at least not here at my shop. If you do pursue this test please let me know how it turns out. -mcguyver 2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field. |
Hi mcguyver
Thanks If I do continue, I'll keep u posted Yair |
yair-BHFC,
a while back I did the math comparing just the difference in KOH usage and I found the break even was around 5 KOH. above this Acid/base if the end point was 3, was cheaper, I would guess that if your oil is already 1.7 then you would see and increase in yield. also I would have to ask if it titrates that low why think about acid/base? -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
I need some help. Recently my oil went from an average titration of 7 to 15-20. I started using an acid pre treatment where you subtract your starting titration from your desired titration and then multiply by . 2 to get the amount of acid needed.
My first batch started at 15 and stopped dropping at around 7. The second batch started at 18 and ended at 7 despite using 2 more ml per liter trying to get the titration to drop below 7. Now my third batch started at 10 and I decided to go back to the original recipe to see if that would work with a lower starting titration. It didn't. After 12-15 hours of heat and circulation the oil still titrates at 8. What am I missing? Thanks, Greg |
Ok, I'm a novice, so I have to ask: In the second line, the "CH3OH 100m (Methanol)" Mark is really speaking of 100 ml methanol, right? Also, in the second line of the BASE side of the reaction, she writes, "2.9 grams for acid neutralisation if titration of 2.6ml achieved" Is the 2.9 supposed to be a 2.6, or did I miss something? And, the BIG BIG questions: Can I practice this in a Dr. Pepper bottle? Can I do this Acid / Base in my appleseed processor, or will it gobble up all the metal? If water shuts down the reaction, how do i remove the water DURING the reaction? Can I do this acid / base process AND an 80/20 - 80/20 base base method, so, I'd call it an "Acid / Base / Base" method. Anyone? Thanks, Frank, a newbie making bio in his backyard in hollywood. |
paperstreet,
yes Mark mean 100 ml of methanol, but this is only for the acid stage. I actually use 120ml. I ignore the amount needed to 'neutralizing' the acid. titration tell you the amount of base needed. removing the water for a home brewer is difficult. for me oil that titrates about 18, I just let the oil settle overnight and drain about 1/2 amount of methanol that I started with. if you need to drain make sure you add the same amount of methanol to the methanol needed for the base stage. 80/20 - of 2 staging base- yes doing a DR pepper sample. possible but not easy its a slow reaction. think hours not minutes. I do all mine in an Appleseed. I don't have any plastic in the pumping circuit.. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
Hi:
I'm not a chemist so I'm having a little bit of trouble understanding the Acid Base process. The purpose is increase yield of BD and reduce soap right? If I convert the FFA to DB by adding Acid and now have acid BD form the acid that I added, and now have to add more KOH to neutralize, don't I create salt water which will now create a lot more soap? If I don't add extra KOH there wouldn't be enough for transesterification, no? What am I missing? Thanks for your help. lcc |
| Previous Topic | Next Topic | powered by eve community | Page 1 2 3 4 5 6 |
Acid Esterification
