Finally had some better luck doing a simple Acid Stage ( heat to 55c add Meth 8%,mix, then add 1 ml sulfuric, moniter Acid value fall to end point, Rest,..... Then BASE stage, Reheat to 55c, Titrate, add required Base Cat in 12% meth and react 1hr)
Testbench ( 1 ltr ) yield same as Testbench single Base stage (low)..!!?? HOWEVER using same method in 1200 ltr reaction got improved yield at 95% ish (unwashed !)looKing great though! Am presently washing so still have'nt got final yield measured. Results indicating that at this Tit 3.5 Acid treatment was worth while.( carn't explain why Mini Test failed to show yield increase...??probly.. aliens..again...!!!! Matthew How did your Acid product wash up ???( normal, better,worse...Yield still there...??? Cheers |
Airborne, great news, and yes you got about the same yield as I got, approx 95%.
Mine has washed, got no frothing on the top as I normally do, about the usual amount of cream cheese on the water / ester boundary. It is lovely fluffy white soap I guess. It is slowly drying (loosing its haze) and should be usable this week. There is no going back! I ended up with 950 litres from 1025 starting. Matt |
