Biodiesel & SVO Forums Home
Acid Esterification
Brown 'mud' after acid/base/base|
what does the BD look like during the later washes? mines usually turning or has turned clear by the end of the last wash.
-dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 soon a 99 dodge 2500 5.9l 24v..-mine |
It does clear up with washing, but not as dramatic as the batches processed with the base stages only.
I do know that acid/base process seems to create more soap than base only..so washing is more important. also making sure the prewashed fuel passed the 27/3 test..
I did several 27/3 tests after reacting, de-meth, and after washing. All the tests passed.
I let the batch settle for 3 days, per Graham's instructions in another thread. I harvested the BD from the top, leaving the mud layer undisturbed. This BD looks clear and stays clear. It passes the "shake em' up" test quite nicely. So the conclusion is I have BD that is VERY difficult to wash (with my washing technique) when I include the acid stage. Next time, I will try a 5% water prewash, and I will plan to let the product settle for a week to purify. Graham says water washing and subsequent drying is eliminated by this method. I hope so. My wash tank will become my settling tank. |
by all means use the 5% prewash...it'll remove 75% or more the soaps..mine is close to 10%. but its not done quite the same way..
most add 5% water and mix for 15-20 minutes.. mines much more passive but works well. I just add 5-10% water to the wash tank then pump the BD/GLY in to the tank. settle and drain the gly/soap out. generally 3 washes are all thats needed. if you prewash forgot misting its too slow... -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 soon a 99 dodge 2500 5.9l 24v..-mine |
Acid Esterification
