Sponsors    Home    Forums  Hop To Forum Categories  Offroad and Marine    2008 Kubota zero turn
I'd like to try running my zero turn on B100. I'm a little hesitant because it cost a fortune, so I need some reassurance. If anyone has experience with high mixtures of biodiesel in 26HP Kubota engine, I'd like to hear about success and mishaps.
Registered: 16 February 2009Reply With QuoteEdit or Delete MessageReport This Post
Yes I have been running b100 for two years in my Kubota rtv 900 it luves it. No problems as long as you make high quality bio.
Registered: 30 June 2007Reply With QuoteEdit or Delete MessageReport This Post
I own a commercial mowing company and put a lot of hours on that machine. Would you have any concerns running B100 in a machine used 500-700 hours during the year.
Kubota don't aproove B100 the last I heard.
I would recomend draining the bio from the fuel tank at the end of the season and topping up with fresh 100% mineral diesel.
Change the engine oil at half the recomended time.
Use good quality biodiesel fuel with antioxidant (Baynox plus) and a biocide (Biobor).
Check hoses and seals for leaks and replace if required.
Watch for diesel bug and carry a spare gauze fiter if you need to change it when you out on your round.
You may use more fuel and have a little less power, but the exhaust will smell great.
Slabs
Home of Good Biodiesel http://www.cambridgebiodiesel.org
2000 Vauxhall (GM) Combo now with coolant type fuel heater. Veg oil blends
1996 VW Passat 1.9 Tdi. VP37 under repair.
Single cyl Petter diesel generator powering tokheim forecourt pump.
Location: Cambridge, United Kingdom | Registered: 21 October 2003Reply With QuoteEdit or Delete MessageReport This Post
