Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Making Soap from the Glycerine by-product    Negative BDG SAP value
Recently I have had several questions regarding determining a SAP value. Some of these related to the BDG already having a pH greater than 10.5. This is an indication that there is excess caustic left in the BDG.
If the pH of your BDG is much greater than 10.5 you have a -SAP value. You will need to either neutralize the BDG with a weak acid such as citric acid or add enough of a whole oil or fatty acid to use up the extra caustic.
I have added instructions on how to determine a negative SAP for your BDG to the KNC SAP Test on my blog.
To quickly and easily work out a recipe for your -SAP (or +SAP) BDG you can use the KNC Soap Calculator.
-Rick
That's something I wasn't aware of. I'd dissolve BDG in equal amount of distilled water (by volume) to check ph. Dilution would effect the ph results I would think.
I usually just check the BDG by dripping some water on it and making a slurry.
That works well for pH paper to get a "ball park".
But if you are going to be using your meter, dissolving the BDG into distilled water would work really well.
-Rick
