Sponsors    Home    Forums  Hop To Forum Categories  "Titrating Oil" article    Another Titration Question
Read-Only Read-Only Topic
I have gone to two different restaurants and have tested their oil. Each one comes in at over 50 drops. I did secure some oil that was guaranteed to have been only used once. It tested in at 6 drops. I also tested my KOH/Water on brand new oil and it came in at 3 drops. I am using Phenol drops. Am I doing something wrong or am I just living near really bad restaurants?
Location: Shingle Springs, CA - foothills | Registered: 19 June 2007Report This Post
ReM
"Drops" is nearly meaningless-- drops are dependant on orifice size.
How many drops per ml is your dropper ??
ReM
B100--
2004 Motorhome CatC7
Southern Oregon
and surface tension (which changes with temperature)
Location: Perth | Registered: 17 April 2007Report This Post
ReM, It is 20 drops/ml.
So your sources titrate at a 2.5. Sounds like good oil to me.
-Jim
www dot FryerPower dot com
I plead the 5th.
Location: Middle Tennessee, Jack Daniel's country | Registered: 10 August 2005Report This Post
Okay, thanks. I guess I shouldn't be comparing it to brand new oil. My first batch I ran came in at .5 so then I thought I was going to have to dump the rest. I have had so much trouble trying to secure used oil. If it's not the SRS technology, it is the "night raiders".
I titrate similar to the method you are using but instead of counting drops I weigh the sample before and after titration. From an earlier post you mentioned you had reloading scales. With scales that can measure a drop this would improve consistency.
Location: Shelbyville Tennessee | Registered: 06 November 2005Report This Post
