Read-Only Read-Only Topic
I was just wondering if it is ok to use peanut oil and do you calculate the batches the same as WVO. I haven't made my first batch yet still getting things together
thanx
Rick
Peanut oil is fine. If it is used, it is WVO.
Andrew
http://biodieselcommunity.org
03 Dodge 2500 B100 homebrew
79 Rabbit B100 homebrew
Location: Northern California | Registered: 27 February 2006Report This Post
I think it has a high gel point. I made some in the biopro and it was a big goop at around even as high as 45 degrees. Anything above 50 it was a clear looking liquid.
40 Gallon 2 tank Biodiesel processors, Well built, Easy to use, Quality parts. pm for pictures and details! http://www.revolution-biodiesel.com/
Running B100 in my Ford 2004 and 2005 F-350 Ext Cab
Location: roscoe, il | Registered: 08 September 2005Report This Post
Affirmative..That is correct
Location: Norse | Registered: 22 March 2007Report This Post
thanx for info
I wanna chime in on something. I started processing some peanut oil again. I did one batch last fall so my knowledge is limited on peanut oil. Well as some know that when doing the 3/27 test, "snow" forms. Well since it behaves strange compared to other oils, does the 3/27 test prove the same results. Is this snow detrimental? I have looked for answers and found none.
Has anyone run a GC on peanut bio and then test with 3/27 to confirm any correlation that the snow is meaningless. I do not see any dropout like tradition oils show the dropout. I guess I am passing the normal test. I run my batches just like I do when using standard soy and have no issues then. Always passing 3/27. I am baffled and would hate to quit processing the oil..
