Home
Forums
General comments about Collaborative Biodiesel Tutorial Project
Getting Started NEED HELP!!
Read-Only Topic|
Build it yourself. GL has a brutally simple, effective system.
http://www.graham-laming.com/bd/ecosystem/state_diagram_new.htm I don't know why people want to watch the reaction. Once you have seen it, it looks like all the rest. The concept of using poly tubing in an extreemly hot enviroment is just not wise. I tend to fall on the safer side of things. My processor is all steel pipe, no sight tubes, no place for plastic to fail. GL's processor is a nice setup and can be easily scaled up in size. 2004 Dodge 3500 Cummins - 2008 F-350 w/ DPF delete - Four Farm Tractors - Two Homes. All on B100 |
and if I knew you lived in Memphis, I would volunteer to help. daw 1986 Mercedes 300SDL 2000 Dodge Cummins |
It's nice to see the level if you are making different size batchs. The poly tank is okay, but steel pipe is much better than poly tubing. Look for one that does not use any poly tubing (other than to suck oil into the system).
If you are mechnically inclined, you could easily build and applesead or cone-bottom. Murphy has some great plans using steel tanks and drums, if you can weld. If you get stuck while building, most out here are very helpful. Just ask away. It's rewarding and less costly building your own system. Much faster buying a turn-key system though. -Rick www.knicenclean.com Making Biodiesel Byproduct Soap Learn how to use your biodiesel byproducts to make great bar and liquid soap!!! "So much to learn and that's no lye!" |
Read-Only Topic
Home
Forums
