Read-Only Read-Only Topic
I live in central Ohio so winters can get pretty cold in terms of biodiesel use (-15 degrees F last year's low but normally it runs around 25-35F). My question is can I run B100 if I equip my vehicle with 12 volt injector line heaters, tank heaters, and filter heaters so it can be preheated before starting? Or is it still a lost cause and I need to blend it B20. My vehicle would also be kept outside and its a 3/4 ton diesel. Are there any other ways to make B100 work in the winter? Thanks for any responses, ideas, or opinions. 4020FarmBoy
In my OPINION, (I don't have much cold weather experience), you would almost need to set up a two tank grease car type setup. Start on winter Diesel then switch over to mildly heated biodiesel. If your coldest biodiesel was at 60 deg F it would flow just fine. Just enough heat to keep it flowing.
I'm single tank heated WVO blend right now. But I will have to be two tank by this fall. (I work in Columbus Ohio.) I've been toying with the idea of using a three tank system.
1- Six gallon winter diesel tank for startup and shutdown.
1- 18 gallon main (factory) tank with biodiesel in it. The heated WVO tank will be right up against this tank and will add a little heat to it just by that. Both tanks are physically inside of the trunk to they will not be directly exposed to cold outside air. In addition the fuel lines will all be bundled with the coolant lines providing HOH heat.
1- 15 gallon heated WVO tank.
Because of the distances I drive I actually need the extra capacity. I need to leave home with about 40 gallons in the tank. 18 + 15 = 33 gallons plus 6 gallons of winter diesel. The 3rd tank is 15 gallons only because I have one hanging around and the price is right.
Maybe I should be using this as a 6 gallon start/stop tank, 18 gallon semiheated blend of Good WVO/Biodiesel, and a 15 gallon WVO tank that MUST be heated to melt higher melting point oil (I get a good bit of hamburger fat).
-Jim
www dot FryerPower dot com
I plead the 5th.
Location: Middle Tennessee, Jack Daniel's country | Registered: 10 August 2005Report This Post
this was one of the factors that caused me to go with WVO instead of bio
86 F250 veggie since May 2005 25,000 miles and counting
78 Benz 300D converted Feb 2006 2,500 miles and no longer counting
92 F250 converted on May 2,2005 14
81 rabbitt
84 benz 300d
Location: New York (south of Buffalo) | Registered: 02 May 2005Report This Post
