Sponsors    Home    Forums  Hop To Forum Categories  "Bubblewashing Biodiesel" article    Air Compressor for Bubbling
Read-Only Read-Only Topic
Does anyone use an air compressor for bubbling, possibly by turning down the pressure regulator real low? Just curious don't wanna buy a aquarium pump if I can use what I already have.
Miles
Location: Plano, TX | Registered: 16 October 2005Report This Post
That would probably work really good. I know you can get a CO2 bubble regulator for $30. That would allow you to control the flow down to 1 bubble per second (or something like that). I'm pretty sure you could get one bigger than that for cheaper.
Great idea.
Andrew
Real men love JESUS!
Location: Fort Worth, Texas, USA | Registered: 30 August 2005Report This Post
Yes, I used my compressor when I bubble washed. I made a bubbler from a 6 inch grinding wheel. Used a small reulator on the end of the 1/8 inch nylon line. Just plugged it into the quick connect on the hose and adjusted the pressure for a fine bubble stream. I no longer bubble wash, though. HTH Smile
WWW.RillaBioFuels.com
You got my curiosity up now why don't you bubblewash anymore?
Miles
I use the glycerine pre-wash. Greatly eases washing while reducing chances of emulsions. Slightly increases yeild as well. HTH Smile
Joe,
Do you have a link or something on the glycerin pre-wash? I can't seem to find anything on it.
Miles
Joe,
I found the glycerin prewash info, but my new question to you would be how do you wash after that if you don't bubble or mist? Or do you not do any post washing?
Joe's description of his method is here
I clicked on his name, then picked "view recent posts by"
JohnO
Location: Moses Lake, WA, USA | Registered: 15 August 2001Report This Post
Thanks JohnO Smile
Never mind Joe Cool
I will definitely try your method.
Miles
Here is a link to info on glycerine prewash.
Location: Australia | Registered: 17 July 2001Report This Post
Sorry, BioMiles, I've been away from the computer for a while. I'm glad you could find the post. Thanks, for backing me up, Johno! Just remember that I have fairly light titrating oil, so it doesn't make a lot of soap to start with, so this method works very well for me. It may not work well with higher titrating oil. My last batch titrated at 5.7 (with a 5 gram base). HTH. Smile
