If it's pre-2004, non-PD, the stock ip will pull wvo.
Not sure about a PD, but you probably need an electric fuel pump to push the WVO. You can also do a electic valve-less design where an electric pump pushes a T'd one-way valve instead of the typical 3 way valves. Veggie-stroke is an example. 1-tank Elsbett VW TDI , 115,000 SVO miles. http://ctbiodzl.freeshell.org/votdi.html and a '92 F-250 with only a FPHE |
