Don't personally have any experience with that engine, however may know what's happening. The smoke sounds like low injector pressure, fuel is not atomizing correctly. Depending on how long you had it tore down, I've saw B100 get sticky in injectors, pumps, and fuel lines open to the air for much time. I'd run it on dyno-diesel for a bit and check the fuel pressure if you can. If it's not a serous issue it will probably clean up after a tank or two. Since it was fine before you tore it down, sure sounds like oxidation of fuel causing ya issues. -K Recycling & Green Fuels Research: www.altfuelsgroup.org Ozone Eating Toys For Big Boys !!: www.suncoastexotics.com Carefully Maintaining A Carbon Neutral Footprint... | |||
You might be onto something there. The engine was unused for 6 months with B100 in the tank, I was just too busy to get the repair done. I will put a few tanks of dinodiesel through it and see if it solves the problem ( thats going to hurt, I have not bought diesel for several years !)I wonder if one of those injector cleaner additives would help? | |||
I've tried Lucas, but after reading the label stating it's "biodegradable", felt it must be something close to biodiesel. Haven't notice any big improvements with any of the major fuel system cleaners. In my case the engine was tore down for a year on B100. Ended up disassembling everything and soaking parts in Methanol just to get it running again. My best suggestion at this point is run some K1 at high levels mixed with bio or dyno diesel and see how that does. Kerosene seems to clean the oxidized bio deposits as good as any special additive I've tested. Recycling & Green Fuels Research: www.altfuelsgroup.org Ozone Eating Toys For Big Boys !!: www.suncoastexotics.com Carefully Maintaining A Carbon Neutral Footprint... | |||
I think you are probably right about the additives. Here in Ireland kerosene is dyed red by the Customs and excise and you will be fined 2500euro if there are traces of that dye in your tank so I cant try the kerosene but I will run a few tanks of dino diesel through it. Thanks | |||
How's that engine running now John? | |||
Powered by Social Strata |
