I imagine you need the intercooler. The engine was designed to use it, if your intake air is not cooled, you may run too hot.
'05 CRD B100 '01 TDi B100 '83 240D B100 |
Anything running over 15psi boost needs a intercooler.
By making the air more dense in advance of the intake manifold you get more air with each combustion, meaning more burn. I've been looking into removing/deleting the ERG, which not only cuts down on dirty air entering the engine but also looks like it would increase temps in the cylinder for a more complete burn.
Go to the TDIClub forums and poke around using their search tool to see what you can find regarding intercoolers and combustion temps. Good luck! Dan 99.5 Jetta TDI, Elsbett single-tank (incl. modified injectors & glow plugs, FPHE, heated filters), running on WVO/Diesel blend |
keelec, if you've got the intercooler and can plumb it, i'd definitely install it. the intake temperaure of non-intercooled air can be well over 200 degrees, meaning the air would be way less dense than intercooled air. intercooled air translates into a few more horsepower, but way more torque. in early early tdis the only difference aside from the cylinder head was the piston stroke and the intercooler- the bottom end was the same as a 1.6 ecodiesel. i have 1 each of these engines in an '86 golf and in a '96 passat- there's no comparison in terms of torque. the tdi is in a class by itself!
