Nobody knows? 5/8"?
What model car is it? I tapped my 96 Passat off the line from the engine head that goes to the heater core. I used 3/4" hose, but where it connects to the head is larger so I spliced into that hose. Run it in a series for the best heat gain. Even if it is supposed to be 5/8" hose, 3/4" can be clamped down to fit.
It's a '99.5 Jetta. The system is currently in parallel with the heater core. I have been told to make it in series with the oil cooler hose instead.
I haven't worked on a 99.5 Jetta, so I am afraid I can't be of much help.
Parallel with the heater core is good.
98 Jetta TDI with aluminim tank HotFox fuel pickup, HOH, FPHE, Coolant Heated VW Oil Cooler Filter,VegTherm, Injector Line Heaters, 6 port Pollak, and 3 port Pollak for Backflushing veg. filter 60,000 grease miles B100 - B20 Main Tank Fuel depending on outdoor temps. 83 Benz 240D 3 Gallon purge fuel tank, Heated Pickup Stock Tank, 12V pump, HOH, Coolant Heated Filter, 16 Plate FPHE, Injector Line Heaters, 2 Greasecar Valves, Looped on Veg., Return to tank diesel.and Injector overflow return to veg. tank |
What is difference between series and parrell?
I recommend the heater core over the oil cooler. I have a similar '98 TDI.
iirc we had a thread on the o.c. as heat source here and it's possible for the water temp. to get above 190*F. I did tie in my TDIHeater at the oil cooler and wrote about it here: http://ctbiodzl.freeshell.org/votdi.html#Conversion Search to "Zerostart tank heater installation." You can find out about how to cut into the lines for a parallel connection. You want serial, so you you'll need a different approach. There isn't a lot of room to work in. Like me, someone would have to use auto parts store hose sections to hook it up. 1-tank Elsbett VW TDI , 115,000 SVO miles. http://ctbiodzl.freeshell.org/votdi.html and a '92 F-250 with only a FPHE |
