Sponsors    Home    Forums  Hop To Forum Categories  Miscellaneous vehicles and engines    problems starting when engine warm
I run a Ford Galaxy TDi in the UK on biodiesel. All works fine been going for 3000 miles. Starts up first thing fine, also starts up fine after an hour or so break. But if I warm the engine up (say 20 mins driving) and then stop for a short period (up to about 40 mins) the car takes much longer to start. I have to hold the key while its cranking over, for say 10-15 or 20 secs.
Anyone any idea why its doing this, and why if I then leave the engine to cool, it will simply start up normally?
revgoonersteve
Location: Bristol UK | Registered: 16 March 2009Reply With QuoteEdit or Delete MessageReport This Post
revgoonersteve
- ouch My dodge was doing the same thing , started fine ran great but did not want to start hot. had to have the injecters changed Eek Eek near $3000. cdn. Starts fine now Tom
SUB
Possibly the temperature sensor diasables glow plugs during cool down period- find the wire and disconnect it-
Suspect low compression to be a contributing factor- two of my diesels have no starting aids and start immediately when above 7 deg. celsius-
\SUB
Location: Vancouver Island, Canada | Registered: 30 September 2001Reply With QuoteEdit or Delete MessageReport This Post
