Home
Forums
Miscellaneous vehicles and engines
Just bought an 05 GMC Duramax and need free advice|
Your truck should run better.You may need a chip,I would.I smoked a 2009 with my SD.
The 2005 does not have a DPF on it, these came out on the 2007 models. I have a 2004 duramax and have put 68,000 miles on it with 100% bio. (It has a total of 108,000 miles on it) I have not made any modifications to the truck.
If it aint broke, dont fix it! But its ok to take it apart and see how it operates. |
Glad to hear that the 05 won't need any modifications. I appreciate the info from both of you. I probably won't be adding a chip, since I have no idea what that means. It's good to hear diesel4me that you have had no problems and needed no mods. I tried to research and it seemed that if I stayed with an 05 or older, that people who posts on various forums weren't have any problems running quality fuel. Can I go straight to B100 or should there be a "break in" process? I bought this truck with the plans to run 100. Also, I have read I can expect a small difference in towing power.
Home
Forums
