Sponsors    Home    Forums  Hop To Forum Categories  6.6 Duramax    01-04 LB7 owners injector problems
Has anyone here had to replace their injectors on their 01-04 LB7 duramax motor. On the site dieselplace.com it is a very common problem and I was wondering what effect positive or negative b100 might have on my newly acquired 02 duramax.
Registered: 07 January 2007Reply With QuoteEdit or Delete MessageReport This Post
I have 01 duramax, GM replaced all the injectors for free because 1 failed at 90,000 miles.
Have been using approx. B50 for 75000 miles no problems. Make sure you know how to change filters on the road, you might plug a filter when the petro junk gets cleaned out of tank and lines. Filters can be changed in about 5 minuets. Always know the quality of your fuel. Bad fuel will cause problems.
Location: Central WI | Registered: 31 October 2007Reply With QuoteEdit or Delete MessageReport This Post
