Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  SVO Connections    VW jetta conversion kit/car for sale
12 gal marine tank in trunk w/copper heat exchanger no intank connections, coolant heated copper coiled fuel filter, HIH, 10 plate FPHE & two 3 port wvodesign fuel valves. Timer/relay purge.
This kit is super reliable and stable. With the timer/relay purge it has only one dash switch so anyone can operate it with no confusion. We just don't drive like we used to... So with that said I would entertain selling the 03 jetta sedan it is attached to. ~190k. Well maintained, due for timing belt. extra set of wheels. The commute for this car is too short. It has plenty of drive left in it for someone with a longer commute.
Merk
03 Jetta TDI 12 gal marine tank in trunk w/copper heat exchanger no intank connections, coolant heated copper coiled fuel filter, HIH, 10 plate FPHE & two 3 port wvodesign fuel valves. Timer/relay purge.
Location: Etna, NH | Registered: January 19, 2006Reply With QuoteReport This Post
bump
Merk
