Sponsors    Home    Forums  Hop To Forum Categories  SVO Connections    need WVO in southeast (LA, FL, AL, MS, GA, AR, TN)
My name is Mike, and I am coming through the Southeast USA in about 2 weeks (~Sept 12). I will be looking for WVO at that time. Would like to pick up around 50 gallons of filtered and dewatered WVO. Must be dewatered! I have been burned with bad oil too many times now.
If you have high quality WVO to share, please contact me by phone (below):
Thanks a lot!
Mike
617-872-5710
This message has been edited. Last edited by: mikemart,
Location: Maryland | Registered: 29 April 2006Reply With QuoteEdit or Delete MessageReport This Post
Hey Mike, since things have been on the mend after Ike, I think I can spare that if you are near my area again.
Troy
Registered: 13 June 2006Reply With QuoteEdit or Delete MessageReport This Post
Hi Troy,
Wow, it is really sad that I may have to drive all the way out to Houston in order to get an oil refill. I have not gotten any interest at all. No one sells oil anymore? I also got zero bites on my request for oil from anywhere in the Midwest. Is this hobby dying??
Anyway, thanks a lot for the offer. I will ask around a bit more over the next 2 days, and then get back with you if I can't find anything on my route. May just extend the trip to Alvin!
Mike
What it is in my area.City codes require that eateries,use a rendering company that cleans their grease traps.Also these companies reguire so many gallons wvo,to clean grease traps free.Unless you can score out side city limits your screwed.
126 diesels yahoo groups
83 SD straight exhaust 94 Cobra
Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost
0-60 10.8, 37 mpg highest
2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer.
