looking for oil to collect? to buy? ----------------------------------------------------------------------------- 40 Gallon 2 tank Biodiesel processors, Well built, Easy to use, Quality parts. pm for pictures and details! http://www.revolution-biodiesel.com/Running B100 in my Ford 2004 and 2005 F-350 Ext Cab
| Location: roscoe, il | Registered: 08 September 2005 |    |
Well the price is $1.50 per gallon in 35 lb jugs straight from the restaurants fryer. I also have brand new canola oil that is $2.60 per gallon in 35 lbs and totes, and hard oil that is $1.90 per gallon in 50 lb boxes.. pm or call 815 979 2583 ----------------------------------------------------------------------------- 40 Gallon 2 tank Biodiesel processors, Well built, Easy to use, Quality parts. pm for pictures and details! http://www.revolution-biodiesel.com/Running B100 in my Ford 2004 and 2005 F-350 Ext Cab
Glenn, Check your PM's. ~Erik Support International Microbusiness - Kiva "The ability to defend a position does not make you wise in doing so." "I'm after sustainable, independent, sensible energy use and application, regardless of what particular energy carrier that may entail. " |
Where is everyone that needs oil located? ----------------------------------------------------------------------------- 40 Gallon 2 tank Biodiesel processors, Well built, Easy to use, Quality parts. pm for pictures and details! http://www.revolution-biodiesel.com/Running B100 in my Ford 2004 and 2005 F-350 Ext Cab
quote: Originally posted by brentsbg: Where is everyone that needs oil located?
The Central Wisconsin area, that is, about 200 miles north of the Illinois border on I-39. You had posted your prices previously in this thread. Given those prices, your location, and the current cost of diesel fuel, it doesn't make economic sense to purchase from you at this time. Have your prices changed or can you cut us a better deal somehow? Thanks, Glenn
