I have a problem regarding use of amberlyst BD 20 catalyst for biodisel. Can it be used for a batch process. If yes, can someone please suggest me a way.
Thanks a lot Deepak |
Deepak,
I believe the Amberlyst BD 20 is intended for FFA esterification however it the FFA content is to high and even if its only moderately high it produces enough water to saturate the resin and renders it useless for biodiesel production. According to the literature you can flush it with methanol and keep going but this seems to be a pain with out somekind of industrial methanol recovery unit... Lastly, just so everyone knows we will be performing several on the spot demonstrations in booth 445 (Thermax-USA booth) so please come by take a lo0k and say hi! We will have a miniature lead lag column set up thanks to Chad utilizing a really cool clear head metering pump so everyone can see the biodiesel coming in and going out. These demonstrations will include pre and post testing. Some of the test being performed for sure are Soap ppm, Total Acid Number and our New Biodiesel Percent methanol test. And we need some help because we would also like to do a total Glycerin/glycerides test so if some one has a line on a GC or some other method please please please let us know. A Demonstration Schedule will be posted later. GCG Causing a Regenerative Economy http://arborbiofuelscompany.com/ http://biodieselpictures.com/v...opic.php?p=1066#1066 |
