Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Dry Washing Biodiesel    20 Grit corn?
Moderators: The Trouts
20 Grit corn?
2013 sponsor
I recently attended a workshop on small scale ethanol production. Rather than using molecular seives to strip the last remaining water from the alcohol, some are running it through 20 grit corn. Sounds like they are using a slow speed column approach just like our wood shavings and other dry wash methods.
It strips out the water and can then be dried out by blowing hot air through the vessel.
Has anyone tried ground corn to dry biodiesel?
'82 VW Rabbit diesel 1.6l na
'83 GMC 6.2l Class C RV
'85 F-350, 6.9l flat bed
'85 E-350, 6.9l cube van
2 Mercedes 300SD's
