Sponsors    Home    Forums  Hop To Forum Categories  Dry Washing Biodiesel    Soap Calculation question
Moderators: The Trouts
GCG
arborbiofuelscompany.com
Reece123,
Your explanations nail it.
In the past chemist have explained that the amount of your sample or the strength of your acid can be varied based on what you expect the concentration of soap to be in the solution tested. However this necessitates a change in the soap calculation and doesn't allow for the simplied 304 or 320 times the ml of acid formula.
Typically, if we are testing biodiesel, even unwashed biodiesel, the amount of soap in solution is of a reasonable ppm amount, that using a 0.01N HCL solution is efficient enough and it makes the math easy.
Note though that in my earlier post regarding a soap test of GLYCERIN, I recommend using more isopropyl alcohol and Phenol Red since almost all the catalyst NOT consumed in soap production, will be in the settled glycerin by-product. This mandates the neutralization of the catalyst prior to doing the soap test.
And going along with what Reece123 said, it would be more efficient at this point to use a 0.1N HCL solution since the amount of soap in the glycerin is also much higher. Holding the sample volume to 10 ml would simply increase the multiplier by a factor of 10 (therefore instead of 304 and 320, you would use 3040 and 3200).
Incidently if you follow Rick Knicely's post in the glycerin soap making portion of the forum, you'll see this is one of steps that can be used in determining your particular glycerin profile and assist you in determining SAP values.
GCG
PS Double D that is an excellent method on Muratic Acid to Lab chemical formula - nice work!
Thanks for the kudos Ant, GCG.
