Sponsors    Home    Forums  Hop To Forum Categories  Dry Washing Biodiesel    My Cheap Eco2pure Experiment
Moderators: The Trouts
I got a tall Rubbermaid trash can at home depot. I made a ring out of Starboard/Sunboard to fit tightly near the bottom. I mounted SS screen of 80 mesh doubled up to the ring. I placed a spigot from Jim D. at the bottom. Next put in about 15lbs. of Eco2pure. Ran 30 gals. of demethed BD through it in about 1-2 hours and was delighted to see clear as can be BD. Also hung a bag filter from the spigot to catch the fine stuff in the Eco2pure. Total cost without Eco2pure about 45 bucks. I did the 5% water prewash. I'm now wondering if I need to use water at all or if I need to even demeth. All comments welcome.
Location: Yorba Linda, CA | Registered: 24 January 2008Reply With QuoteEdit or Delete MessageReport This Post
Maybe I should rephrase. My experiment demonstrates a very inexpensive way for small homebrewers to get into dry washing. Inexpensive, easy to build, quick to use, and great results.
Thanks for that info! We sell a lot of Eco2Pure and customers are always asking for a low cost solution. If you keep on experimenting and let us all know the results ill give you a 10% discount on your Eco2Pure. Just email me with your name nathan@biodieselexpertsintl.com
Nathan DeMartino
www.drywashbiodiesel.com
Registered: 20 February 2008Reply With QuoteEdit or Delete MessageReport This Post
Ant
I suspect no to the water and perhaps to the demeth. Ecopure will absorb some meth too. Only so much though. Then meth will keep soaps dissoved. Soaps unlikley to come out into ecopure while dissolved. I think.
As recommended by the manufacture they say to demeth first then EcoPure, and DO NOT pretreat the EcoPure with methanol.
I sell EcoPure and as you say it works great, though I must admit it works even better through the custom designed rigs it was designed for.
Location: Derbyshire UK | Registered: 28 November 2007Reply With QuoteEdit or Delete MessageReport This Post
