From Wikipedia, the free encyclopedia
Perlite is an amorphous volcanic glass that has a relatively high water content, typically formed by the hydration of obsidian. It occurs naturally and has the unusual property of greatly expanding when heated sufficiently. It is an industrial mineral and a commercial product useful for its light weight after processing. Diatomaceous earth — also known as DE, TSS, diatomite, diahydro, kieselguhr, kieselgur or celite — is a naturally occurring, soft, chalk-like sedimentary rock that is easily crumbled into a fine white to off-white powder. This powder has an abrasive feel, similar to pumice powder, and is very light, due to its high porosity. The typical chemical composition of diatomaceous earth is 86% silica, 5% sodium, 3% magnesium and 2% iron. Diatomaceous earth consists of fossilized remains of diatoms, a type of hard-shelled algae. It is used as a filtration aid, as a mild abrasive, as a mechanical insecticide, as an absorbent for liquids, as cat litter, as an activator in blood clotting studies, and as a component of dynamite. --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
john
I stand corrected on the differences between the two. But my original thought still stands. Since perlite is very porous what its capabilaties to use as a drywash material would be. Trc If you can't dazzel them with brilliance, then baffel them with bullchit. |
