Sponsors    Home    Forums  Hop To Forum Categories  "Filtering Oil" and "Pretreating Oil" articles    NSH Used Engine Oil Regeneration machine (Personal Album)
Read-Only Read-Only Album
NSH Used Engine Oil Regeneration machine by william ho (created on )Gallery | Comments
Application
NSH GER gas engine oil System is particularly suitable to regenerate internal-combustion engine oil including diesel engine oil, gasoline engine oil and internal-combustion engine oils. GER series can effectively remove colloid, oxid, acid, pitch, particles, impurities, water, gas in the oil. Specially, GER can restore the color of used internal-combustion engine oil and remove the scent rapidly.
Ⅱ. Edges of GER
Design according to different customers’ needs.
Purify blend oils.
Low operation cost.Low maintenance and replacement expenses.
High regeneration rate.
Automatic reverse wash system will extend the lifetime of filters and improve the performance of the filters.
High performance security system including pressure protection device and automatic temperature controller makes purifier operate safely.
Small size, light weight, low noise.
Other series products
VFD series Insulation oil ,transformer oil purifying plant
TF series turbine oil ,hydraulic oil purifying plant
LV series lubricating oil ,machine oil purifying plant
The slideshow requires Flash Player 9.0.124 or higher.
Please click here to install it.
