Sponsors    Home    Forums  Hop To Forum Categories  "Titration Station" article    titration confusion
Read-Only Read-Only Topic
A question about titration...I picked up some oil today and here's how I did the titration:
10ml of ethonal plus 1ml of oil, then added 3 drops of phenylthalien. I then dripped my 1 gram lye/1 liter water mix into the previous mix...it turned at 10 drops, which is quite a bit less than 1 ml! Repeated the test with the same results.
New oil at home...3 drops to turn purple...used oil at home (french fries!)...7 drops to purple.
Is this normal? Did I do it right? I was expecting somewhere in the 1-2 ml area.
Thanks for any help...
Tim
Location: Centennial, Colorado | Registered: 18 July 2005Report This Post
Seven drops is not 7ml, though, if i read you correctly. Did your new oil take 3ml or 3 drops?
Location: Victoria BC | Registered: 24 November 2004Report This Post
dva
Raven23,
From Timay...New oil at home...3 drops to turn purple.. Guess you missed it. Big Grin
Timay, sorry to say it but, no, you aren't doing it right.
Here is a quick run down.
1, put 10 cc of isopropanol in the beaker or whatever you use to titrate.
2, add the three drops of phenppthalein.
3, Add some of your 0.1 titration solution, drop by drop, until the iso turns pink and holds it's colour for around 20 second while you stir it.
4, now add the 1 cc of oil and shake vigourously
5, add drops of 0.1 solution , shaking between each, until you get back to the pink again.
That's it.
As there are around 22 drops to a cc, if you used 5 drops then you would need 4.5 + 0.25 =4.75 gramm/litre of fuel
Don't worry, you will soon be titratiog like an old hand. Smile
regards
dva
Location: Yorks,England | Registered: 30 June 2001Report This Post
Thanks DVA. I have been a bit confused about blank titration. My instructions say I should stop as soon as the solution turns pink. I found this a bit confusing. I believe this is why some of my titrations were slightly different after testing the oil a second -third -fourth time. Sometimes I add 0.1 solution until it barely turnes pink, other times I add a drop or two more to obtain a bright pink. I never knew which one was better.
Can't wait to try my next batch of oil to see if results will be more consistent.
Location: Central Texas | Registered: 12 May 2005Report This Post
What's a drop between friends?
Location: ลึก ประเทศอินเดีย | Registered: 03 March 2001Report This Post
