I have a 99 F-250 SD with the 7.3 PowerStroke. I ran B-100 until it got too cold to do so then switched to a 50/50 mix of BD and PD.
It's been about 5 months now. I'm not sure of the milage, I'll have to look it up.
So far no ill effects. The truck only had 60k miles on it so apparently there was no sludge to break up and collect in the filter. I checked the filter, it was clean. I changed it anyway and kept the old one to use as a back up.
I wash my fuel but am going to making some batches of unwashed BD to experiment with. This stuff will be setting for a period of months to evaporate all methanol off and also for soap to settle out.
My washing and drying processes are the most time consuming of them all and it unwashed fuel will work with not ill effects I'll defineatly be using it.
I would think that if you can afford to leave the fuel sit for a period of months, somewhere around 4 months or more, you are going to get about the same fuel quality that you would if it were washed and dried.
My only real concern would be byproduct getting into my tank. That cannot happen! What ever need to happen to prevent this I'm all over it.
I believe that settling for a sufficient amount of time would be the trick. I suspect that after some set period of time all byproduct (glycerol) will have settled out and that unless some how methanol and catylist were introduced into your fuel tank, there could be no additional byproduct available thus there being no more to settle out.
I understand that there is some amount of time that the reaction will continue. For most it's not an issue because they are washing and therefore stopping the reaction and removing all potential ingredients that could allow reaction to continue.
Question for the experts, Am I on the right track with my logic about after a period of time all reaction will be complete and eventually will settle out will occour and will be no way of having any more byproduct to settle?
Or am I all wet?
Wayne
Very funny Scottie, now beam down my clothes.
